Basic Stamp and Solenoids
I am using a 12V box solonoid (Heavy-duty 12 Vdc pull-type solenoid. Continuous duty. 14 ohm coil. 2.2" x 1.65" x 1.45" box frame with four threaded mounting holes in two sides. 0.5" diameter slotted plunger with hole for pin extends 1.25" when retracted. Solder lug terminals.
I am trying to connect it to my basic stamp to create a locking mechanism. (the stamp wil control 3 different solonoids based on user input). Can anyone give me some advice on the best way to connect my solonoid to my basic stamp? Thanks!!
Take a look at these Darlington Arrays. I suspect one of them will meet your needs:
http://www.allegromicro.com/sf/2001/
Bruce Bates
http://www.irf.com/product-info/datasheets/data/pvn012.pdf
Hope that helps.
Dave
