DC Voltage Monitor
Hello,
I am looking to monitor and record a battery voltage as it is charging/discharging over a period of time and store the voltage value in the Stamp to lookup later. Does anyone know of a serially-typed interface volt meter or similar that can transmit it's displayed voltage in this fashion? Does Fluke make anything like this, or any other source - I know they make meters that interface to PC with software but I just want the volt value written to the Stamp.
I know this is an odd application but any assistance would be appreciated! Thanks
Brian
Brian
You can use an analog to digital converter (ADC) chip to get the data into your Stamp, there are several of these chips you can use. A resolution of 10 bit (1024 steps) will be about the minimum you need, 12 bit is better.
If you have a plain BS2 I doubt you will get all the data from charge and discharge voltage, in fact you will need to save the currents too, into the tiny EEPROM. for the BS2 is 2 kByte for program and data.
A BS2p or a BS2pe would be more suitable as the have 8 or 16 banks of EEPROM respectively.
Regards and succes,
Klaus
I'm not sure what type of stamp you are intending to use but, Klaus Is right, a BS2p is probably what you want. Besides memory it has 1-Wire capability. Which brings me the point - if you want to monitor a battery the DS2760 from Dallas Semiconductor is very capable. It has 10 bit adc to monitor voltage, a 12 bit adc to measure +/- current flow. I think it also has a thermometer and and it logs total current in or out of the battery and a bunch of other stuff. You can look at the data sheet online and see if it does what you want. If you havn't used 1-Wire before expect to spend a little time reading however.
Good luck.
Tristan
