I expect that Chris savage has answered your question.
I have a servo motor that sends an output pulse train back to the controller which could be read with PULSIN.
The pulses are generated by a toothed magnet attached to the rotor.
As eash tooth passes a sensing coil built into the motors housing, a pulse is generated.
The pulses are amplified and returned as TTL level signals.
In this case you would definitly need a limiting resistor.
I expect that one should always employ a limiting resistor when interfacing the Stamp to the outside world.
If PULSOUT was what you were looking for, then yes, but you must have a common ground with the stamp.
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
Bean.
