Editor doesn't find the Stamp
OK, this is my first try, my first program to download to the Stamp...running PBasic 2.5, Win 98, BS2. I input a canned program, selected RUN and am told that "No Basic Stamp was found." I have doubled checked the wiring, checked for voltages to be where they should, checked for continuity in the cable. I need suggestions for things to check. Do I have to do anything special with the computer so it uses the serial port properly...what port settings, e.g.? This is all pretty new to me.
You may have to turn off the FIFO buffers.· Here is a simple way of doing this:
1.· Go to your Control Panel.
2.· Click on Systems.
3.· Click on Hardware Settings.
4.· Click on Device Manager.
5.· Scroll down to Ports.
6.· Double click on the Com Port that you are using.
7.· Click on the Port Setting tab.
8.· Click on the Advanced button.
9.· Uncheck the FIFO box.
10. Click on Okay on the way out.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Here's some additional info:
When I do a RUN ---> Identify, for COM 1 (which I believe is the port I'm using) I get:
· Loopback = Yes
· Echo = Yes.
· Device Type = (nothing)
Does this say anything useful here?
I am having the same problem (still) trying to run my Stamp from my old DOS computer.
I like to use the old computer because it's there.
Everything works on my WIN98 machine: same program, cable etc.
I can connect and run both in WIN98 and from a DOS window running under WIN98
But no luck on the old machine and the power is on.
BS2 (industrial version)
9V to pin 24, GND to 23
Measure 4.99 @ pin 22
RX (DB9-2) to pin 1
TX (DB9-3) to pin 2
DTR (DB9-4) to pin 3
GND (DB9-5) to pin 4
I have LEDs thru 1K from both SIN and SOUT to GND.
When I try to identify (Ctrl-I) the stamp, there is activity on both SIN and SOUT: 5 brief pulses. Result: Loopback-YES Echo-YES
If the stamp is powered off, I see 5 brief pulses on SIN, nothing on SOUT (of course). Result: Loopback-YES Echo-YES
If the stamp is powered on, but I disconnect SOUT from the DB9, I see one pulse on both SIN and SOUT, Loopback-YES, Echo-NO
Power off, SOUT disconnected yields one pulse on SIN, Loopback-YES, Echo-NO
I'm at a loss. Can you help?
Thanks.
Running XP Pro, Belkin F5109U USB-serial adapter as COM7, 9600-N-8-1, no flow control, FIFO disabled (also tried with FIFO enabled, no luck).
That's it, I promise!
http://www.parallax.com/detail.asp?product_id=800-00030
Regarding lac's issue:·· Make sure that you are running the latest editor version 2.1.· You mentioned that you are using a canned program, make sure that there isn't a com port directive in your code already.· If this doesn't work, please give the Parallax tech support a call at 1-888-997-8267.
Dave
Dave Andreae
Tech Support
www.parallax.com
Thanks for the help- I tried on a desktop with built-in serial port; it worked like a champ <sheepish grin>. I actually remember now reading about the USB-serial converter issue, just kinda forgot about it.
Thanks again,
Steve
