4 inch seven segment display
I am new to this and have been trying to work with a large seven segment display that I purchased at Jameco (Part Number 105591 made by LIGITEK)
and am having no luck. I have been successful with following the projects in What’s a Microcontroller, Student Guide using a
small seven segment display from Parallax... I get power the segments light up etc.
But when I use the same Resistors – 1 k (brown-black-red) for the large seven segment display I get nothing...
Help...
Thank you
Help...
Thank you
To drive the large segments, you'll probably need darlington transistor package (whose part number escapes me right now) and perhaps a larger power supply.
A 1K resistor is probably WAY too large. The result is the LED doesn't get enough current to light.
Attached is the seven segment display info PDF
Thanks!!!
Jon Williams
Dallas Office
So if it is a common cathode can I use it?
Also, note there are 5 LED's *in series* for each segment. Each LED takes 1.4 volts. So you need at least 7 volts to drive this thing -- 9 volts controlled by a ULN2803 (with a current limiting resistor) would be better. Definitely do-able.
can I use a ULN2003A with this? or only the ULN2803?
Sorry I am new at this
Thanks for your help!!!
Jon Williams
Dallas Office
