program trouble
I am having trouble with displaying the temperature on the LCD (exp.#28). The DS1620 circuit works and shows with DEBUG, so I think the problem is with my code. My last try is below. Could you please help me with this. Thanks!
Stu
' {$STAMP BS2}
' {$PBASIC 2.5}
' Program Description
' This program measures temperature using the Dallas Semiconductor DS1620
' temperature sensor and displays the results in fahrenheit.
' I/O Definitions
DQ············· CON···· 0·················· ' DS1620.1 (data I/O)
Clock·········· CON···· 1··················· ' DS1620.2
Reset·········· CON···· 2···················· ' DS1620.3
E·············· CON···· 8···················· ' LCD Enable pin· (1 = enabled)
RS············· CON···· 3······················ ' Register Select (1 = char)
' Constants
ClrLCD········· CON· $01···················· ' clear the LCD
CrsrHm········· CON· $02····················· ' move cursor to home position
DispLf········· CON· $18······················ ' shift displayed chars left
DispRt········· CON· $1C······················· ' shift displayed chars right
DDRam·········· CON·· $80····················· ' Display Data RAM control
CGRam·········· CON· $40····················· ' Custom character RAM
Line1·········· CON· $80···················· ' DDRAM address of line 1
Line2·········· CON· $C0··················· ' DDRAM address of line 2
RdTmp·········· CON···· $AA···················· ' read temperature
WrHi··········· CON···· $01····················· ' write TH (high temp)
WrLo··········· CON···· $02······················ ' write TL (low temp)
RdHi··········· CON···· $A1······················· ' read TH
RdLo··········· CON···· $A2······················ ' read TL
StartC········· CON···· $EE····················· ' start conversion
StopC·········· CON···· $22···················· ' stop conversion
WrCfg·········· CON···· $0C··················· ' write config register
RdCfg·········· CON···· $AC·················· ' read config register
' Variables
tempIn········· VAR···· Word··················· ' raw temperature
sign··········· VAR···· tempIn.BIT8············ ' 1 = negative temperature
tSign·········· VAR···· Bit
tempC·········· VAR···· Word··················· ' Celsius
tempF·········· VAR···· Word··················· ' Fahrenheit
LCDout········· VAR···· OUTB··········· ' 4-bit LCD data
char··········· VAR···· Byte··········· ' character sent to LCD
' DATA statements
Msg· DATA· "Present Temperature = "
' Initialization
Initialize:
·DIRS = %1000000111111000··········· ' setup pins
· GOSUB LCDinit···················· ' initialize LCD for 4-bit mode
· HIGH Reset··································· ' alert the DS1620
· SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]WrCfg, %10]···· ' use with CPU; free-run
· LOW Reset
· PAUSE 10
· HIGH Reset
· SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]StartC]······· ' start conversions
· LOW Reset
· char = DDRAM
' Program Code
Main:
· GOSUB Get_Temperature························ ' read the DS1620
· DEBUG HOME
· DEBUG "<<<DS1620>>>·· ", CR
· DEBUG SDEC tempC, " C··· ", CR
· DEBUG SDEC tempF, " F··· ", CR
· GOSUB· LCDcommand
· READ (Msg + tempF), char
· GOSUB· LCDwrite
·· PAUSE 1000·································· ' pause between readings
· GOTO Main
' Subroutines
Get_Temperature:
· SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]RdTmp]········· ' give command to read temp
· SHIFTIN DQ, Clock, LSBPRE, [noparse][[/noparse]tempIn\9]·········· ' read it in
· LOW Reset······································· ' release the DS1620
· tSign = sign································· ' save sign bit
· tempIn = tempIn / 2·························· ' round to whole degrees
· IF (tSign = 0) THEN No_Neg1
· tempIn = tempIn | 123························ ' extend sign bits for negative
No_Neg1:
· tempC = tempIn······························· ' save Celsius value
· tempIn = tempIn */ $01CC······················ ' multiply by 1.8
· IF (tSign = 0) THEN No_Neg2···················· ' if negative, extend sign bits
No_Neg2:
· tempIn = tempIn + 32························· ' finish C -> F conversion
· tempF = tempIn······························· ' save Fahrenheit value
· RETURN
·· LCDinit:
· PAUSE 500················· ' let the LCD settle
· LCDout = %0011·············· ' 8-bit mode
· PULSOUT E,1
· PAUSE 5
· PULSOUT E,1
· PULSOUT E,1
· LCDout = %0010·············· ' 4-bit mode
· PULSOUT E,1
· char = %00101000····················· ' multi-line mode
· GOSUB LCDcommand
· char = %00001100··········· ' disp on, crsr off, blink off
· GOSUB LCDcommand
· char = %00000110··········· ' inc crsr, no disp shift
· GOSUB LCDcommand
· RETURN
· LCDcommand:
·· LOW RS················· ' enter command mode
·· RETURN
· LCDwrite:
· LCDout = char.HIGHNIB········ ' output high nibble
· PULSOUT E,1·············· ' strobe the Enable line
· LCDout = char.LOWNIB········ ' output low nibble
· PULSOUT E,1
· HIGH RS················· ' return to character mode
· RETURN
Stu
' {$STAMP BS2}
' {$PBASIC 2.5}
' I/O Definitions
' Constants
' Variables
' DATA statements
' Initialization
Initialize:
· LOW Reset
· PAUSE 10
· HIGH Reset
· LOW Reset
· char = DDRAM
' Program Code
Main:
· DEBUG HOME
· GOSUB· LCDcommand
· GOSUB· LCDwrite
· GOTO Main
' Subroutines
Get_Temperature:
No_Neg1:
No_Neg2:
· RETURN
·· LCDinit:
· PULSOUT E,1
· PAUSE 5
· PULSOUT E,1
· PULSOUT E,1
· PULSOUT E,1
· GOSUB LCDcommand
· GOSUB LCDcommand
· GOSUB LCDcommand
· RETURN
· LCDcommand:
·· RETURN
· LCDwrite:
· PULSOUT E,1
· RETURN
This will give you an idea. After positioning the LCD cursor, you can use this routine to put "tempRaw" into the LCD:
Jon Williams
Dallas Office
' {$STAMP BS2}
' {$PBASIC 2.5}
' I/O Definitions
' Constants
' Variables
LCDbus········· VAR···· OUTB··········· ' 4-bit LCD data
char··········· VAR···· Byte············ ' character sent to LCD
index·········· VAR···· Byte············· ' space for index
' DATA statements
' Initialization
Initialize:
· LOW Reset
· PAUSE 10
· HIGH Reset
· LOW Reset
' Program Code
Main:
· DEBUG HOME
· GOSUB· LCDcommand
· READ (Msg + index), char
· GOSUB· ShowTemp_LCD
· GOTO Main
' Subroutines
Get_Temperature:
· tempIn = tempIn | $FF00························ ' extend sign bits for negative
No_Neg1:
No_Neg2:
· RETURN
·· LCDinit:
· LCDbus = %0011·············· ' 8-bit mode
· PULSOUT E,1
· PAUSE 5
· PULSOUT E,1
· PULSOUT E,1
· LCDbus = %0010·············· ' 4-bit mode
· PULSOUT E,1
· GOSUB LCDcommand
· GOSUB LCDcommand
· GOSUB LCDcommand
· RETURN
· LCDcommand:
·· RETURN
LCDwrite:
· LCDbus = char.HIGHNIB··········· ' output high nibble
· LCDbus = char.LOWNIB··········· ' output low nibble
· PULSOUT E,1
· RETURN
· ShowTemp_LCD:
· IF (tempIn.BIT15 = 1) THEN········· ' check sign bit
··· char = "-"························ ' - for negative temp
· ELSE
··· char = " "························ ' blank for positive temp
· ENDIF
· GOSUB LCDwrite······················ ' write sign character
· tempIn = ABS tempIn··············· ' convert tempt to absolute value
· FOR index = 2 TO 0···················· ' loop through three digits
·· index = tempIn DIG index + "0"······ ' get digit from temp, convert to decimal
··· GOSUB LCDwrite···················· ' write digit
· NEXT
· RETURN
I've attached the code.· Much of it is based on Jon William's work with the DS1620 and DS1302, as well as some mods from Tracy Allen.
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
