SX-Key with external oscillator
I have a question about using an external oscillator with the SX-Key.
My project is using a precision external oscillator to run the Scenix, so the Scenix RTC can be used for timing of other projects.
I have the SX-Tech board with an SX-28 chip, the SX-Key programmer, and a 4 mHz ovenized crystal oscillator with TTL output.
What I did was to assume that the SX-Key could override a moderately high oscillator impedance, so I connected the oscillator's TTL through a 2.2 kOhm resistor to the OSC1 connector on the SX-Tech board.
I used the following programming directives:
DEVICE SX28L, OSCHS, TURBO, STACKX
IRC_CAL IRC_FAST
FREQ 4_000_000
It works just fine. I can program the Scenix with the oscillator running, and the Scenix runs just fine both with and without the SX-Key attached to the SX-Tech board.
But I'm wondering if I'm stressing the SX-Key excessively. I haven't seen any documentation on how to use it with an external oscillator.
Is what I'm doing safe for the SX-Key?
thanks,
David
I talked with Chip who designed the SX-Key and he says "yes it is safe, not at all a problem".
Shouldn't be a problem. If you destroy the SX-Key I could replace it anyway. But don't do that on purpose please.
Bean.
David
