Debug Terminal : transfer the received datas on a file .txt
Hello !
I have a program wich use the Debug Terminal to·see datas (Basic Stamp 2).
When my program execution is finished, i would like to transfer the received datas on a file .txt
How can i do ?
Regards.
Laurent (France)
How can i do ?
Regards.
Laurent (France)
Sid Weaver
New Combo LCD Backpack
· If I want to get data from the hyper terminal (off of a stamp), can I use serout, and just match the baud rates and parity?
thanks
agentile
SEROUT 16, pin, baud, [noparse][[/noparse]data, 10, 13]
10 and 13 are the ASCII characters for Line Feed and Carriage Return.· If you have any problems let me know.· I have used this procedure for years to capture data to Excel and have taught several people how to do it.· Excel can handle up to 65,000 rows and over 52 columns of data.
Sid Weaver
File/Properties/Settings/ASCII Setup/Append line feeds to incoming line ends
I like to make it an option in my PBASIC programs too, with a bit flag. LF is sent if the flag is 1 or not sent if the flag is zero. That uses the "REP" modifier for DEBUG or SEROUT
Tracy Allen
www.emesystems.com
Sid
You can use "Stamp Daq" for this project, this is free software.· Here is a link for more information:· http://www.parallax.com/html_pages/downloads/software/software_basic_stamp.asp .· Please make sure to scroll down to the Stamp Daq software, you will see an information file and a download file.· If you have any more questions please feel free to e-mail us.
Dave
Re:
Hello !
Thank you !
It's a very good free software.
It's exactly that I search·!
Thanks !
Regards
Laurent Besset
I have been using the code you sent on how to get hyperterminal to do a carriage return. Thank you. You said you have been using hyperterminal to write to excel files. Could you explain how to do that?
thanks,
agentile
Stamp Off.
Open Excel.· Create a file.· Put a title of some sort at the top.· Save as a text file, data.prn.· .prn specifies a file delimited by spaces.· Close Excel.
Open Hyper.· Click on Transfer/Capture text.· Browse to find the data.prn file you created.· Click on Capture.
Stamp on.· Everything you see on the Hyper screen will be captured to the data.prn file.· When you have the data you want captured, click on Transfer/Stop.
Close Hyper.· Stamp off.· Open Excel, click on data.prn.· You will be taken to a special screen where you can select the starting row, set your column width, and so.· When you are finished the data.prn file will appear with the captured data.· You can now edit Excel to get rig of the garbage and format the data any way you wish.
This should do it for you.
Sid Weaver
4 digit serial LED
Thank you very much.
agentile
