LCD display of 12 or 16 key keypad
Hi all, I need to know what·should to be done in order to send data through a fiber optic cable and to have it be received for display by the PIC16F873. Basically what I need to do (for a short project) is·use a 12 or 16 key keypad and have it so that when up to 4 digits are pressed on the keypad, it sends data·(the keys that have been pressed)·via fiber optic cable to a alphanumeric LCD display.
···· I figured I would need to encode the data, send it through the fiber, and have the data, received by the USART of the controller, decoded in which time it would then be sent to the LCD display using USART again maybe? I was looking through the PIC data sheet and I also stumbled upon the MSSP function. Should I use that and the USART? I'm new and the manual supplied to me is useless. I could use all the help I can get!
Privitere
Note: Moved to "Sandbox" by Jon Williams (moderator)
Post Edited By Moderator (Jon Williams) : 11/29/2004 2:01:40 PM GMT
Privitere
Alrighty, and now, the BASIC Stamp solution:
First, look for "BASIC Stamp 1 Application Notes (516 KB)" in the www.parallax.com -> Downloads -> Documentation page.· A keypad exmaple can be found on page 81.· Ignore the parallel LCD, and just use the Keypad example.· There's an alternate way to use a keypad on page 155.·
On the other side of your fiber, a serial LCD will make the design much simpler.· In place of the wire to the LCD, you will need your TTL-Optic-TTL hardware.·· For this, you can use the Scott Edwards Serial LCD: www.parallax.com -> Products -> Accessories Portal -> Audio/Visual.· Here is a link to the simplest of the serial LCDs: 2x16 Serial LCD, Non-backlit.· This product page has links to documentation with circuits and example code.·
After that, it's a matter of integrating the two example programs into one for your BASIC Stamp.
While I'll take the whole solution handed to me on a silver platter (or copper clad sheet), I'm really just after some direction on where to start digging. I've done mechanical engineering in a "prior life", and am still struggling a little with finding information on the electronics stuff. I can't seem to filter the wheat from the chaff.
John R.
8 + 8 = 10
http://www.electronickits.com/kit/complete/fibe/ck1500.htm
The kit comes with 1m of fiber, but can be used with cables upto 16m in length.
·1+1=10
This year I'm not worried about the full 100' depth, probably only 35' feet or so (1 atmosphere is a common rating for readily available components like thrusters and affordable camera bags, etc.) Lots of stuff to learn and work out.
If only water wern't so wet...
John R.
8 + 8 = 10
