multiple mosfets on basic stamp
www.al-williams.com/fetrly.htm
With the circuit listed above on each BS2 pin, can the stamp turn on 8 to 10 of these MOSFETs at the same time?
If so, how fast is the switching?
Thanks.
Jack
Thanks.
Jack
-dave
This is not a sig. This is a duck. Quack.
Thanks for the reply Dave.
The Fets will be connected to 12v solenoids.
They need to fire within a few hundred milliseconds.
Sounds like it will work fine.
I was going to use relays, but I like the FET idea much better.
Jack
In any event, a few hundred milliseconds is a reasonable amount of time for a BS2. It cycles around 100 uSec per instruction. You could do 8 separate outs in around a millisecond.
I had assumed that. Thanks for the confirmation.
And thanks for the 8 outs/pm info. The platform will be moving, I'll be using that information. [noparse]:)[/noparse]
Jack
