Fast Real Time Clock
I'm trying to mesh two·BS2s that need to sample separate data at a relatively fast rate.· In order to determine what events logged by one·BS2 corrospond to events logged by the second BS2, I'm hoping to insert some sort of reference time (not nessesarily in seconds, possibly in "counts") that they can both access in order to timestamp the data before putting it on an eeprom.· Ideally, I'd like the "unit" of the timer to in the range of 1/100th of a second or less, but 1/10th is doable.· I'd like the·duration before·it resets/rolls back to 0·to be atleast 10 seconds.
What "viable" (aka relatively cheap and easy) options are there for a fast reference clock for both chips?· Can I just get a 555 hitting up a counter?
Thanks in advance!
Dave
Thanks in advance!
Dave
BUT you will need 8 I/O pins on each stamp to read it.
Bean.
There are real time clock chips, such as the PCF8593 that have a programmable frequency output that can be used for timing. If absolute timing accuracy is important.
Tracy Allen
www.emesystems.com
