Color matching "minimax"
Hello,
I am trying to find a color matching one of 8 preset colors using a BS 2, BOE and TAOS Color Sensor, similar to the M&M Sorter...
The pdf article which comes with the example color matching program at the Parallax software CD-ROM mentions a "minimax" value. Calculating such a value seems quite easy, as well as retrieving the color which has the smallest color minimax.
However my script seems unable to see the difference between, for example, purple and red, and green and blue. So I must be doing something wrong
I use the following line of code to calculate the minimax value:
Color_Diff = ( ABS ( Input_Red - Red_Value) ) + ( ABS ( Input_Green - Green_Value ) ) + ( ABS ( Input_Blue - Blue_Value ) )
Input_Red, Input_Green and Input_Blue are the color values which are read from the color sensor, and Red_Value, Green_Value and Blue_Value are the variables containing the RGB values of the stored color.
Am I calculating the minimax value the correct way?
Vic
Vic
Color_Diff_Red = ABS ( Input_Red - Red_Value )
Color_Diff_Green = ABS ( Input_Green - Green_Value )
Color_Diff_Blue = ABS ( Input_Blue - Blue_Value )
Color_Diff = 0
if ( Color_Diff_Red > Color_Diff ) then
Color_Diff = Color_Diff_Red
endif
if ( Color_Diff_Green > Color_Diff ) then
Color_Diff = Color_Diff_Green
endif
if ( Color_Diff_Blue > Color_Diff ) then
Color_Diff = Color_Diff_Blue
endif
Vic
