LM34/35 temperature probe
I recently bought a LM35 TEMPERATURE PROBE, and I'm trying to make it work with the Javelin.
I'm using the ADC-converter class to interface the lm35, but I don't get the expected results: The lm35 is returning 0,272v as expected (0 + 10mv/degC = 0,272v corresponding to 27,2 degres). But the ADC-class is returning an integer value·like 82! How does 82 match with 27 degres?
The outputvalue returned from adc is not changing, when temperature is increasing or decreasing.
I think that my problem is that the·output voltage from lm35 is·only changing 10mv·per 1 degre. How can·I scale the outputvalue so it's readable with the ADC-class?
Has somebody tried to use lm34 or lm35 with javelin? How should it be interfaced? is ADC the correct way to read temp values?
Christian G.
Post Edited (ChristianG) : 11/22/2004 8:02:28 AM GMT
Christian G.
So allow me this simple answer....27deg Celsius is 80.6deg Farenheit.· Where 27.777degC is 82degF.
Could you be getting your metric/SAE units confussed?
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
