LED's in a series with one resistor question
I found this article on the web and wanted to make sure I was reading it right, I will be buying 225 LED's that run 2.3v@20mA
I want to connect as many as I can together and use one resistor per grouping. I will be using a 12volt switchable wall transformer rated at 500mA.
From my calculations I can connect 5 LEDs with one 100ohm resistor? But it seems the power supply should be able to handle a lot more than just 5 leds, what am I missing? Heres the example I found. I will need to connect 200 LED's and try to run them off as few transformers as possible, is there something else i could use to get my current up without having to buy a 4amp (200 x 20mA) transformer?
A red, a yellow and a green LED in series need a supply voltage of at least 3
A combination of LEDs in parallel and serial would most likely be the best bet. One circuit of 5 LEDs in series with a resistor could be hooked up in parallel with another 10 LEDs and a resistor in series.
I just did an experiment and I could only get 5 LEDs lit up with a 9 V battery and a 220 Ohm resistor (a 470 Ohm resistor worked with 5 LEDs but they were just a little dimmer). If I added a 6th LED to the circuit, none of them would light up. Hooking up an additional 5 LEDs and a 220 Ohm in parallel to the other circuit also worked.
Post Edited (ubikuberalles) : 11/19/2004 6:31:07 AM GMT
