NX1000's DS1307 grief
HAIL ALL,
i have DS1307.BSP running on a bs2p on my nx 1000 board
i have it wired as:
pin 0 -> SDA
pin 1 -> SCL
pin 4 -> D0 - switch
pin 5 -> D1 - switch
pin 6 -> D2 - switch
pin 7 -> GND
the debug screen displays
DS1307 Demo
65:65:65
my scope sees
0v on pin1 of the ds1307
5v on pin2 of the ds1307
5v on pin5 of the ds1307
5v on pin6 of the ds1307
0v on pin7 of the ds1307
5v on pin8 of the ds1307
any help?
rox on
nick bernard
i have it wired as:
pin 0 -> SDA
pin 1 -> SCL
pin 7 -> GND
DS1307 Demo
65:65:65
my scope sees
any help?
rox on
nick bernard
If you're looking at the same program (DS1307.BSP) that I am, which was originally found on the High-TechGarage web site, you will note that the EEPROM "switch" needs to be reset for the first run of the program, and anytime thereafter when you want to have the program initialize the real time clock. This should help with that issue:
http://www.gorobotics.net/articles/article.php?name=realtimeclock
Note: It appears that High-TechGarage is no longer in business under that name.
Bruce Bates
thx for the input yo, i got the program from the parallax site though. supplied specifically for the nx1000 board. in any case your input seems applicable and i'll give it a shot.
rox on
nick bernard
nick bernard
Do you have pull up's (4k7) on SDA and SCL ??
Klaus
i dont pick up any activity after i simply put a pullup (47k) on pins 0&1, (sda scl)... i figured there would be some signal movement with the i2c commands.
but even if the i2c interface is failing then why doesnt the sqw pin on the ds1307 oscillate?
you can find the soucecode that i'm running on the parallax site
www.parallax.com/detail.asp?product_id=28137
thx
nick bernard
The demo program has lots of bells and whistles. When I am confronted by something that doesn't work, I like to strip it down to the bare essentials.
That program uses in2 to read the state of the sqw pin. To do that, pin 3 of the DS1307) has to be connected with a pullup resistor, say 10kohms, to Stamp p2. With that program you should see activity from your 'scope on p0, p1 and p2. The sqw pin should have a period of 1 second as seen on the DEBUG screen and on the 'scope. Yes? No?
Tracy Allen
www.emesystems.com
