problem downloading to BS2sx
I'am using the Basic Stamp Super Carrier board with the BS2sx. I have problem downloading my program. It keeps telling me to check the power supply and cable when I press "run" and sometimes it will give a message"no stamp found".·If I press "run" many times, it will work sometimes. Does anyone know what the problem is and how to solve it?
Thanks..
Thanks..
Jon Williams
Dallas Office
I'am sure my power supply is good. Instead of using a 9V battery at the terminal, I connected my variable power supply set to 9V to the terminal. I also changed the serial cable and it is still giving the same problem. Is there anything else you think might might cause this problem?· Could the lenght of the serial cable have anyting to do with this? I'am using a 10ft cable. It's strange because it works after I execute it a couple of times. When it doesn't work, it detects the loopback, but not the "echo". Thanks.
Jon Williams
Dallas Office
