Watchdog
A Stuart
Anyone having any experience or ideas regarding watchdogs ?
I'm using a Dallas DS1232·WD (watchdog)·to reset the Javelin in case it crashes.
Problem is, from the time the WD pulls down and releases the RESET pin to my main() starts to execute, it takes to long.
The WD will time-out and do a new reset before I have a chance to tickle it in·the main loop.
regards,
anders
regards,
anders
a serial interface to the Javelin (2 I/O) and a watchdog output (1 I/O).
On power up the programmed watchdog in the SX28 is off until
explicitly turned on by the javelin. The only 'problem' is then
reprogramming the javelin, because the watchdog may reset·the
javelin while it is being programmed. My simple solution to prevent
that is either a jumper to disconnect the WD output from the javelin
reset pin, or recycle power just before programming the javelin.
(I turn on the WD after 10 minutes which is plenty of time to
reprogram the javelin)
regards peter
I have the same experience with the DALLAS DS1232,·The Javelin·is to late to trigger.
You can use the MAXIM MAX705 to get a watchdog. You must generate pulses within 1.6
sec on the WDI input, if not·there is a reset on pin 7 (200msec).
Pin 1 must be connected to pin 8. This works fine.
Regards Rob.
Thanks for the the tip. Problem is the MAX705 is twice the price of the DS1232 wich is already a bit expensive I think.
I've found a Fujitsu chip; MB3773 at a reasonable price. I have not tested it yet. I will be back when I have.
Regards
/Anders
The MAX705 was ~€ 4,-· I saw in·the datasheet of the MB3773·that the max·watchdog time is·~·1000msec,·i wonder if this is·enough, my experience is that it must be longer than ~1.2 sec.
Regards Rob.
This has an extended mode that extends the normal timeout 500x
And make sure to connect the watchdog reset output pin via a jumper
to the javelin reset pin, so you are able to program your javelin by
removing that jumper.
regards peter
