Problems with the SX/B Sound Command setup.
Hi All :-)
I have been playing with the sound command. I used the Piezo speaker and two 10uF caps from the "What is a Microprocessor" development set. According to the information in the SX/B Help file under Commands/Sound the schematic calls for a cap to the SX chip port pin and to the + on the Piezo speaker. Then also a cap across the Piezo speaker. The sound was so faint I could not hear it. After advice from Parallax I removed the cap across the Piezo speaker and the sound level was loud enough to hear from 20 feet away in a quiet space. What worked was the + pin on the 10Uf cap to a SX port pin. The – pin on the 10uF cap to the + pin on the Piezo speaker. The – pin on the Piezo speaker to ground.
Thank You
David Winchell
Thank You
David Winchell
Jon Williams
Dallas Office
