LED dot matrix + basic stamp - beginner needs help
hey,
I'm working on a school project where I'd like to use a LED dot matrix and a basic stamp 2x. I've never used a LED matrix, so I was wondering: the dot matrix has got 40 leds and needs 2.6volts to run. What piece of hardware should I use to connect those LEDs to my basic stamp (considering there are only 16 pins, and 6 of them are already set as inputs)? Any recommended readings/tutorials?
Thanks for your help!
Frankie
Frankie
Take a look at the Maxim MAX7219 which should do what you need. Here is a link to that product: http://www.maxim-ic.com/quick_view2.cfm?pdf_num=1339 . Maxim is pretty good with their sample policy, so ask for a sample, instead of purchaing one.
Bruce Bates
Anyway thats just my $0.02.
Chris
Frankie
