any way to rig 5 cd players to run off one acdc converter?
i am using 5 cd players in a sculpture project and would rather not buy 5 acdc converters...the cd players were only $10 a pop. they run on 4 aa batteries or 4 volts from a dc line in. is there any way i could splice from an acdc converter and run electrical wire to the battery terminals to get them to all run off one converter? would i use the 4 volts, the 1.5 aa volts, or 5 times 1.5 volts since i have 5 cd players. any ideas?
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
does anyone know what diamter solder wire i should use for a 30 watt gun when doing resistors and the like?
Large gauges (something like a 12 gauge copper wire) is really for soldering 12 guage copper wire or sheet metal (such as rain gutters).
Small gauge (like 20 gauge) is for delicate work, such as printed circuit boards with tiny ICs.
If your solder is too big a diameter, you find that you get too much in the wrong places.
Also, it is important to clear the tip of excess solder. When I was a kid, I used to shake the iron, but solder splatters were found everywhere.
Now, I have a brass scouring pad that I just scrub the tip with and the excess sticks to the brass. I suppose you could use iron wool, but it rusts, can easily catch fire, and creates a magnetic dust which sticks to the backsides of speaker or magnitized tools.
Oh, the 30 watt gun will also work faster with smaller gauge solder. And, you may want to use a solder wick [noparse][[/noparse]copper mesh tape] to drain off excess solder.
G. Herzog in Taiwan
