Detecting Loud Sound aka The Clapper Circuit
I want to detect a sound threshold to trigger an action on my Boe-Bot.
I've searched the archives and google and come up with two kinds of answers 1) detailed circuits over my newbie head 2)general suggestions that surely would work if I could implement them.
I found a dedicated clapper circuit here http://home.maine.rr.com/randylinscott/dec97.htm. This looks like a great dedicated circuit but I was wondering how I could use the stamp to take the place of the "IC3" and/or other parts of the circuit. Other post suggest keeping the 555 timer to strech the pulse in order to make it easier to detect. Thoughts on this?
I simply want the stamp to complete a simple directive upon detecting the sound (ie turn servo x seconds using pulsout) so I won't need another detection to turn it off.
Code/Circuit Suggetions. Ideas?
Thanx
Thanx
Jon Williams
Dallas Office
1) In my circuit the BS2 would take the place of IC3 Flip Flop. I'll want to use a pin to check the 555 timer and as you said I could use another pin to send the reset signal if I didn't want to wait for a rearm. OK so far right? If I wanted two claps I would simply have to add a counter variable for that pin right?
My question arise from circuit mods by losing the flip-flop. First what does the 47 UF capcitor do in this circuit? Also RM the potiometer is for circuit tuning right? So I could adjust it to tune out background noise right? I have a LM359 dual ap-amp. can I use that in this circuit?
Any more suggestions? this circuit posted at home.maine.rr.com/randylinscott/dec97.htm
