use of UARTs in the background
Does anybody know where I can get some more information on using the buffered serial communication in the background?· I know how to·set up the Uarts and use them in the main program to communicate with each other but am I missing something about the background that could speed up my program?
atekippe
ISU
atekippe
ISU
[noparse][[/noparse]Error IDE-0028] Unhandled exception in JVM:java.lang.OutOfMemoryError.
Exception thrown in file 'C:\Program Files Inc.\Javelin Stamp IDE\lib\lang\StringBuffer.java' at line 272
Is there a way to clear the memory so it never reaches it's upper limit or another way to get around this?
Here is the code we are running
Routine to receive entire responce in buffer
static void bufferMessage(){
c = 0xff;
count = 0;
while (count <1){
//if(rxUart.byteAvailable()){
c = (char)rxUart.receiveByte();
if(c=='\n'){
count=1;
buffer.append(c);
Main Program
public static void main(){
while (count < 101) {
buffer.clear(); // clear buffer
Uart commands poling epoch4 for Peak Thickness
txUart.sendString("PH? \r\n"); // ask for peak thickness
bufferMessage(); // call receive subroutine
if (count>99){
System.out.println(count);
System.out.println("out of loop");
else {
x=buffer.length();
count=0;
while (count <x){
l=(char)buffer.charAt(count);
if(l==m){
u=count;
if(l==n){
v=count;
count=count+1;
if (x>1){
buffer.delete(u-1,x); // deletes from buffer 6 to end of string
buffer.delete(0,v+4); // deletes front 3 chars in buffer
// System.out.println("
Peak Thickness [noparse][[/noparse]in]
String s = buffer.toString(); // prints to screen remaining chars
System.out.println(s);
atekippe
ISU
append() calls expand() that creates a new string if the
buffer is too small. And because there is no garbage collection
you eventuelly run out of memory.
You can better use a simple char array plus index pointer to
store c. This minimizes code and speeds up your application.
static char[noparse]/noparse buffer = new char[noparse][[/noparse]100];
static int index=0;
static void readMessage() {
· int c;
· index=0; //start new message
· while (true) {
··· while (!rx.byteAvailable()) ; //wait for input
··· buffer[noparse][[/noparse]index++] = (char)(c = rx.reaceiveByte());
··· if ((c == '\n') || (index>=100)) return;
regards peter
atekippe
ISU
