Control 12VDC motors (H bridge plans)
Hello:
I need to control two 80RPM 12 VDC motors. My budget is reduced so I want to use things that I have to control it. Now I have a Pololu dual motor controller which drive 1A per motor at 12VDC. I was thinking about using this controller as a PWM driver to drive a H-Bridge (if I can build it is better).
Does anyone have some good plans of an H-bridge to drive about 3A or maybe more?
Is it possible to do what I'm thinking?
THANKS!!
THANKS!!
Jon Williams
Dallas Office
Jon Williams
Dallas Office
I don't know much how to do that but I think it can be done with some kind of H-Bridge design.
-dave
This is not a sig. This is a duck. Quack.
Thanks!!!
http://cache.national.com/ds/LM/LMD18245.pdf
http://www.fairchildsemi.com/ds/MM/MM74HC595.pdf
There are a couple of good app notes on the 595 floating around the Parallax download site as I recall (anyone remember the AN# or the N&V column?), and the datasheet for the '245 is quite good at explaning things like the current sensing and the PWM. They also have some very useful notes on microstepping a bipolar motor with a pair of '295s in half-, quarter- and eighth-step modes using the PWM stuff. Very slick.
-dave
http://mysite.verizon.net/res0z5qw/Brooksbots
and click on the link to "Excuse II" for schematics. Just make sure that you add the 10K pull down resistors to the leads from the PIC to the SN754410. If you don't, when the reset is held low for any length of time, the output from the SN754410 tends to wander high which turns on all of the bridge legs (this is a bad thing!).
Choose the MOSFETs that deliver the current necessary.
Rick
I·bought my copy on-line at the Servo magazine bookstore. The book also talks about using these H-bridges and drivers with your BASIC Stamp and other processors.
