Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
vapor pressure formula — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
mize
15
2004-11-09 12:14
edited 2004-11-09 19:47
in
BASIC Stamp
tracy, do you have a formula that i can use with a bs2 to calculate
saturation vapor pressure?
Gerry Shand
45
2004-11-09 14:40
edited 2004-11-09 14:40
Typically these are pre-tabulated values that you can find in a thermodynamics text or text book. What is the fluid medium?
Gerry Shand
Tracy Allen
6,667
2004-11-09 19:47
The dewpoint calculation I wrote for the Sensirion SHTxx requires the logarithm of the saturation vapor pressure over water. Maybe that would help. The program listing is here:
www.emesystems.com/programs/dewpoint.bsx
Using the BS2 to calculate dewpoint, given temperature
http://www.emesystems.com/programs/sht1xdp.bsx
Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
[noparse][[/noparse]url]http://www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank">www.emesystems.com/OL2sht1x.htm" target="_blank"> Readings from Sensirion SHTxx sensor used to calculate dew point
More on the SHTxx.
I hope that helps. A small modification is required for EW over ice. As Gerry said, an alternative is to use a table lookup, from temperature to EW.
Tracy Allen
www.emesystems.com
Sign In
Register
to comment.
Gerry Shand
More on the SHTxx.
Tracy Allen
www.emesystems.com
