MAX3100 substitute???
Can someone recommend a substitute component for a MAX3100 UART?
Maxim has a 9 week lead time to get these parts and I can't locate a source in Ottawa or via Digikey.
The MAX3100 provides the buffer capacity I think I need for my BS2p24 serial comm project.
Thanks for your suggestions.
Bob
······ Bob, Ottawa
W75 54 17·· N45 18 30
·········· G16 #27
Bob
······ Bob, Ottawa
·········· G16 #27
Digikey does seem to have current stock.
Tracy Allen
www.emesystems.com
You may find this to be a real helpful search engine for finding chip availability:
http://www.findchips.com/ . Presently they show a number of resources for the MAX3100.
Bruce Bates
I was certain Digikey indicated back order when I inquired last week. Maybe I am getting as old as my kid says I am.
Thanks for the FindChips link. This will be quite useful in the future.
Bob
······ Bob, Ottawa
·········· G16 #27
with his students.
Some limitations of the 3100 though:
1. It *won't* do 'inverted' data -- you must have a max232 driver in there.
2. It *only* buffers 8-bytes
3. I think it is pretty limited where number of data bits and parity are concerned.
4. You *must* have an external crystal on it to set the baud rate.
I used the MAX3100 initially because one thing it has going for it is IrDA capability.
www.emesystems.com/BS2IrDA.htm
Also in its favor is a very good low power mode--The chip can sleep at low power and wake up when there is activity on the serial line. Do be sure you order the correct crystal. It is a weird frequency!
Tracy Allen
www.emesystems.com
It was indeed the MAX3110 I found to have huge lead times. The MAX3100 appears to be easily available.
I have ordered a MAX3100, a MAX3222 and a crytsal. I expect this will address my serial woes. By the time I get this issue resolved and am ready to build a permanent circuit the MAX3110 will hopefully be available.
Thanks for the info.
Bob
······ Bob, Ottawa
·········· G16 #27
Digi-Key has ample stock for the MAX3110ECWI if that's helpful.
Bruce Bates
I saw this part but have been scared away by the SO packaging. My solderig skills are good but SO parts (and surface mount) are a significant challenge.
Are sockets available for SO parts?
Many thanks...
Bob
······ Bob, Ottawa
·········· G16 #27
