Control AC Outlets
I am looking to do a small Xmas light display and need to control some AC outlets.· I am wondering what is the easiest/cheapest way to control AC. I have seen some topics for relays, triacs and MOSFets.· I am rather new to the basic stamp, and everything I have ever interfaced/controlled is DC circuits. Just looking for some guidance.
Chris
Chris
·Safest and easiest way would be with X-10. No Ac wiring needed and the code is really easy. The units you would use can be found here http://www.parallax.com/detail.asp?product_id=27940·for the interface and here for the module http://www.parallax.com/detail.asp?product_id=27941
Stephen Swanson
Technical Support
sswanson@parallax.com
Jon Williams
Dallas Office
a. Relays are the simplist but must be chosen with respect to load currents and voltages. John and Stephen mention the safety issue, which is very important. Relays also work in switching applications where the cycle time is 1 second or greater.
b. Triacs are good high speed solid state switches but need extra circuitry between them and the stamp. These devices have no moving parts so they lend themselves well to high speed switching.
c. In my work, MOSFETS work well in PWM applications switching DC at high rates of speed. In order to make them switch AC, you need to rectify to DC, filter and then use more than one (two or four depending on how you want to operate them) to build an inverter bridge. Lots of circuitry and work involved plus potential safety issues.
So the X-10 route is the better way to go for the least amount of fuss.
Gerry Shand
This kit also gets you an RF remote, so you can control your house yourself.
The only drawback is I don't know of an off-the-shelf command (like the XOUT command) to implement the communications from the Stamp to the 'Firecracker', so you'd have to implement the protocol yourself. The protocol is very well documented, though.
Also note using the 513 you'll have to wire from your stamp to the module. With the Firecracker, you can be rooms away.
Hope that helps!
Al Williams
AWC
http://www.awce.com
There, that fills in the only question. Now I would go with the Firecracker without hesitation.
You get an RF-driven solution, so your BS2 and BOE (or whatever) can be anywhere in the house.
