DS1302 and BS2SX
I am experimenting with the DS1302 and I have been trying to use the code included in the AppKit. on the Parallax website and I just can't seem to get anywhere. I am attaching the code and as you can see there is already a problem with the syntax here:
Initialize:
'Set Time and Date to 05/18/98 - 3:00 PM
'NOTE: Date must be set only once for every power-up of DS1302 chip.
Day = $02 'Monday
Month = $05 'May
Date = $18 '18th
Year = $98 '1998
Hours = $15 '3:00 PM (in 24-hour mode)
Minutes = $00
Seconds = $00
GOSUB SetTimeAndDate
LOOP: ***** HERE IS THE ERROR - 'LOOP' must be proceeded by 'DO' ****
'Read out all date and time values and display them in two formats on
'the debug screen.
GOSUB ReadRTCBurst
DEBUG HOME,"LONG FORMAT DATE AND TIME:",CR
GOSUB PrintLongDate
GOSUB Print12HourTime
DEBUG CR,CR,"SHORT FORMAT DATE AND TIME:",CR
GOSUB PrintShortDate
GOSUB Print24HourTime
GOTO LOOP
So I changed it to:
Initialize:
Day = $02 'Monday
Month = $05 'May
Date = $18 '18th
Year = $98 '1998
Minutes = $00
Seconds = $00
DO 'LOOP: ***** HERE IS THE ERROR - 'LOOP' must be proceeded by 'DO' ****
'the debug screen.
GOSUB ReadRTCBurst
GOSUB PrintLongDate
LOOP 'GOTO LOOP
and now the program runs but no time appears on the Debug Terminal. All I get is:
day, 00, 2000
12:00:00 AM
00/00/00
00:00:00
and nothing else happens or changes.
Can anyone give me any pointers. Attached is the program file.
Initialize:
Day = $02 'Monday
Month = $05 'May
Date = $18 '18th
Year = $98 '1998
Minutes = $00
Seconds = $00
'the debug screen.
GOSUB ReadRTCBurst
GOSUB PrintLongDate
GOTO LOOP
So I changed it to:
Initialize:
Day = $02 'Monday
Month = $05 'May
Date = $18 '18th
Year = $98 '1998
Minutes = $00
Seconds = $00
'the debug screen.
GOSUB ReadRTCBurst
GOSUB PrintLongDate
LOOP 'GOTO LOOP
day, 00, 2000
12:00:00 AM
00/00/00
00:00:00
' {$PBASIC 2.0}
Jon Williams
Dallas Office
I prefer to USE PBASIC 2.5 and started the program off with
' {$STAMP BS2sx}
' {$PBASIC 2.5}
Could it be that the AppKit was written 5/18/98 and has old code in it?
Well why I was writing this I changed it to {$PBASIC 2.0} and it tokenized successfully. Thanks for your help. Let me play arround with it some more and see what I can come up with.
Once I get the the hang of it maybe I can write the program to run in PBASIC 2.5.
Jon Williams
Dallas Office
day, 00, 2000
12:00:00 AM
00/00/00
00:00:00
Let me change my pins from 7, 8 and 9 back to how it was originally in the program at 0, 1 and 2. Also I am using a 2k resistor from the stamp pin to the I/O pin (6) of the DS1302. Does this appear to be a good value. I have seen some make reference to a 1k resistor and others to a 10k resistor.
P.S. it does not make mention to using a resistor in the AppKit for the DS1302.
Luke
Simply amazing, everything seems to be working fine since I change back to pins 0, 1 and 2. I am using the original code and change the following back to:
'Set I/O pin states and directions
OUTS = %0000000000000000 'All logic low
DIRS = %0000000000000111 'I/O 0,1 and 2 are OUTPUT, rest are INPUT
prior to this, all the code was the same except I changed the following to:
DIRS = %0000001110000000 'I/O 7,8 and 8 are OUTPUT, rest are INPUT
I also change the wiring on the stamp as necessary to pins 7, 8 and 9.
Is there anything else in the code that I did not see that would have kept pins 7, 8 and 9 from allowing this to work?
Luke
