Parallax Neon Sign Display — Parallax Forums
Chris SavageChris Savage Parallax EngineeringPosts: 14,406
edited 2004-12-23 18:25 in BASIC Stamp
Of course I can't find it now in my plethora of video files, but a few days ago I was showing·a Client some Parallax Videos I had downloaded from the website a long time ago...In there was a video of a Neon Sign from a show that was the Parallax Logo, doing all kinds of neat display effects.
If anyone from Parallax knows what I'm talking about, I was wondering, was that running off a BS1 or BS2, and also how it was switching the individual segments of the Neon Lamps (Relays, SSR?)...Is a schematic available?· It gave myClient an interesting idea and a reason to buy some Parallax products.
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
    edited 2004-11-04 17:32
    I know about that -- I wrote the code!
    It runs on a BS2p. I used the BS2p simply for speed as part of the delay routine actually goes out and checks an IR receiver for codes from a TV (the BS2p does the Sony·IRC decoding)·remote which is used to control cycle speed and which·cycle (pattern)·is running. The code was written in PBASIC 2.0 syntax (will be simpler when I have time to update to 2.5).
    We used and OPTO-22 interface to turn on each element of the displays (all letters are separate). This all came about as my boss (Ken Gracey) and I popped into a neon shop to see if there was a neon tube that could switch on without delay (unlike the flickering we're used to with office lights). The guy who owned the shop showed us that this was possible with the right ballasts and we commissioned him to build the tubes for us. Anyone who visits our California office can see the display in action.
    I've attached the (old) code -- I don't have a schematic because it it so straightforward and we simply connected the neon circuits to the OTPO-22 board (with appropriate modules installed, of course).
    Jon Williams
    Dallas Office
    Post Edited (Jon Williams) : 11/4/2004 5:52:48 PM GMT
  • BeanBean Posts: 8,129
    edited 2004-11-04 17:43
    Jon,
    Any chance of a link to the video that Chris talked about ?
    Bean.
    edited 2004-11-04 17:45
    I do not have that; sorry.
    Jon Williams
    Dallas Office
    edited 2004-11-04 17:48
    Thanks Jon...While we were talking about the possibility of this guy doing his Neon Project, I was talking about when I used to DJ years ago how we had built a lighting controller for the light system, which was mostly different colored 110VAC Spotlight Lamps.· Back then I used cherry switches to control relays which switched the individual lights on/off inside the cabinets.· As you can imagine the wiring for this was a nightmare, and required the lights to be right in front of the table.
    We're DJing again years later and I was actually thinking of building my own lightning controller using a BS2 or BS2P40...It would have auto/manual modes for the lights etc.· But I am still trying to decide on a method of switching the lights on/off that can be more easily controlled remotely using TTL signals...
    Normally the only high-powered devices I build are Power Amplifiers...So in terms of lighting I haven't done much on the higher-voltage stuff using logic-level interfaces...So many choices...TRIACS...SSRs...
    So I have to add that to the project list, and your NEON SIGN code does some of what I will be doing with the lighting.· What modules did you use on the OPTO-22 board, if you don't mind my asking?
    If we build a full-fledged lighting controller, we'll post the schematics and code on our project website.
    Knight Designs
    P.O. Box 97
    (607) 535-6777
    edited 2004-11-04 17:55
    We used modules that would handle the 120 VAC loads that we plugged in. I don't remember the current rating -- maybe someone in our California office can go look at the sign and tell you.
    Jon Williams
    Dallas Office
    edited 2004-11-04 17:56
    I just meant, were they SSRs?
    Knight Designs
    P.O. Box 97
    (607) 535-6777
    edited 2004-11-04 17:58
    Yes, the OPTO-22 modules are in-fact SSRs (optically islolated, of course).
    Jon Williams
    Dallas Office
    edited 2004-11-04 18:01
    Thanks Jon!· BTW, that was a good selection of patterns on that display!· Good work!
    Knight Designs
    P.O. Box 97
    (607) 535-6777
  • dandreaedandreae Posts: 1,375
    edited 2004-11-06 12:49
    Hi guys,
    The relay modules are rated at 3 amps.· Here is a link with more information:
    http://www.parallax.com/detail.asp?product_id=27322
    Dave
    Dave Andreae
    Tech Support
    dandreae@parallax.com
    www.parallax.com
  • DonivanDonivan Posts: 23
    edited 2004-11-11 00:26
    Have you thought about using Electroluminescent wire (EL-Wire) instead of Neon? It's almost as bright and uses DC-powered inverters. Very flexible, and you can get a variety of colors. I'll be using that for an art project using either a BS2sx or a Rabbit module. I could show you some photos if you're interested.
    -Donivan
    edited 2004-11-11 01:10
    Yeah,
    I was playing around with some of the blue stuff. I'd like to see the photos.
    Bean.
    edited 2004-11-11 01:26
    I will be running a similar project myself using standard incadescent bulbs...The Neon thing was a Client's project.· I don't know exactly what he's got in mind.· My project will be a lighting contoller for our DJ business for the lights...Although I haven't decided what I will use to switch the lights on/off yet.· I/O Modules are rather expensive.
    Knight Designs
    P.O. Box 97
    (607) 535-6777
    edited 2004-11-11 05:35
    Chris,
    I was poking around our network and I found the schematic for the neon display sign (attached). This sign is operating in our demonstration room at the Parallax office. I think it is the best demo we ever made using our products (of course, I made it. . duh. . with Jon's programming help as usual). Jon had the basic code working in an afternoon but the assembly of the sign took several days.
    The infrared remote numbers 0-9 select the blinking pattern and the channel up/down adjusts the speed. We had a lot of fun putting it together. The neon person I hired to make the individual letters subsequently went out of business, though. He told me that he often took on interesting projects "one too many times" like our logo neon sign with individual power supplies.
    For what it's worth, neon handles quick on-off control very well. In fact, one of our customers made a Stamp-controlled neon sign for a shopping mall in So. California:
    http://www.parallax.com/html_pages/resources/custapps/app_better_mousetrap.asp
    Works in a very similar fashion.
    1608 x 663 - 237K
  • John Raplee, JrJohn Raplee, Jr Posts: 32
    edited 2004-11-11 06:00
    ····· Oh my.· Chris made a "Better Mousetrap".· I must say I like Chrises much more.· He did however have a mouse or "POW" as he calls it, eat a hole through it, and got out...· Still he ended up being caught.· devil.gif· Anyhow, You can see Chrises Mousetrap here : http://www.lightlink.com/dream/chris/mousetrap.htm·.· Chris makes some really cool stuff, and has a talent for this stuff, as you have probably noticed by now.· cool.gif He has given me the interest in learning a bit of this Stamp stuff....· I am going to get one of the Learner kits here, soon.· Anyhow, just figured I'd post.. hop.gif
    Ken Gracey (Parallax) said...
    Chris,
    My Computer Specs
    _______
    "I had no professional training, I gave it my all, I have no regrets" -William Hung
    _______
    edited 2004-11-12 00:18
    Ken, thanks for posting the schematic...I will show it to the Client who was here when I played the video.· Should give him·an appreciation for the simplicity of the design, given the power of the display.· It would be interesting to see a Video of the other Neon Sign you posted the link to.· I have seen it before, but there's not enough detail in the photo to really make it out.
    John, there are several people on this forum who have made their own interesting projects too.· Just as you see mine as inspiration, you will find others on here who have posted links to their own projects.· I have found myself inspired by others work too!
    Knight Designs
    P.O. Box 97
    (607) 535-6777
    edited 2004-11-13 01:33
    Chris Savage said...
    My Computer Specs
    _______
    _______
    edited 2004-11-30 16:53
    Here's an image of some EL-Wire on an art car and a costume. This is at night with no ambient light, so it will seem a lot brighter than if there were some light pollution.
    -Donivan
  • Harry StonerHarry Stoner Posts: 54
    edited 2004-12-02 15:42
    Donivan that is a very cool photo. Like a bug, I am attracted to the light ...
    Harry
    edited 2004-12-02 16:43
    Thanks! My most recent BS1 project involves the spinning "beacon" thing on the top of the art car. I'm going to control those light segments as it spins.
    Well, that's the theory anyway....now on to implementation....
    Hello,
    We posted the details of the Parallax neon display here: http://www.parallax.com/html_pages/resources/custapps/app_neon.asp for future reference.
    Donivan, if you have some details about your neon display send them over!
