using 2 ADC0831 w/same clk and cs
advice please
i am trying to display two separate voltage on·two lines of LCD and i'm using two adc0831. i connected·both cs to same pin and also both clk's to same pin too. i get reading from one ADC but not the other. the o/p are connected to two pins.
what am i doing wrong??
At this point, I would first wire up one and test at a time and make sure that each works individually before attempting to operate them in concert again.
Let's say that /CS for your first ADC0831 is connected to P4, /CS for your second ADC0831 is connected to P5, both CLK lines are bussed to P6, and both DO lines are bussed to P7.· Something like this (not tested) should work for reading the both ADCs:
Post Edited (Andy Lindsay) : 11/3/2004 6:20:44 AM GMT
