5volt regulator added to circuit not working?
I am making a simple emitter-detector switch
It works on 5 volts
I want to use the 24 volt supply in the project
Can I just add the 5volt regulator like I show it in the drawing?
I tried a adjustable voltage regulator (its all I had on hand) but even though the led lights up showing I have power to the ir led
the transistor wont trigger the relay. Oh and i forgot to show the diode across the relay fot the inductance spike.
In case the attachment thing isn't working: http://www.dowvideofutures.com/images/question1.jpg
It works on 5 volts
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
for what I can see there is a mistake in the connection of the relay, it should be connected betwen the·+ 5 V·and the collector (that you call drain) of the transistor.
NOT TO THE COLLECTOR AND THE EMITTER, this way when the base of the transistor is positive, the collector will go low energizing the relay.
In your way, the relay, will sink current from the resistor that beeing of 1Kohm, will not allow the relay to move because of the 0,005 A current TOO LOW.
Ohm's Law will tell you everithing in this case.
best regards
I will redo a schematic showing how I put the variable voltage regulator in and see if you can figure out why its not working.
As this schematic was drawn by someone else and I added the voltage regulator, I need to understand what I did wrong.
Thank's
Knight Designs
P.O. Box 97
(607) 535-6777
