I mean the SX28AC/DP -- an now I'm happily programming it in SX/B (PBASIC-like language for the SX). SX/B supports interrupts and I have used this fact to create a virtual LED driver for a couple projects. You can see those in the SX/B help file that can be downloaded from that the SX/SXB forum.
The SX has a similar architecture other micros, though I wouldn't call them schmacy; in fact, they're somewhat spartan. But the are very fast (one instruction per cycle) and allow for the creation of virtual devices when needed.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams
Dallas Office
how involved is this flavor of microcontroller-
what are the startup costs?
what external devices are necessary for the sx chip?
i like dips; is it a dip?
how fast?
how cheap?
LucidTronix has a tutorial for driving two 5 x 7 LED Matrix displays using shift registers. It only requires 3 pins from a micro-controller: http://lucidtronix.com/tutorials/18
Startup costs for the SX chip are a programing device called an SXKey or and SXBlitz. Since the chips are EOL, they are quite reasonably priced. Support through www.SXlist.com may be helpful. Available in DIP.
Essentially the SX28 chips are a refined PIC.. more speed and better generic features. You could use a PIC for a 5x7 LED driver as well. That would require a PIC programer and take you in a direction that might be a bit more demanding.
The nicest thing about the SXes are that Parallax provided some good free tutorial material and SX/B for programing. You can also program in assembly language.
I am at a complete loss as to how this thread suddenly appeared to become active again. But the SX chips are still very handy to use as an adjunct to the Propeller... especially for i/o such as 10 key input and LED matrix output. Both of these applications can be done without even adding an external crystal if SPI communications is used.
Jon Williams
Dallas Office
or are you just referring to the SX chip itself (ubicom??)?
Are these fancy shmancy pics?·
honestly haven't even looked at them.
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
Jon Williams
Dallas Office
how fast?
how cheap?
thx
nick
Jon Williams
Dallas Office
http://www.parallax.com/tabid/138/List/0/CategoryID/15/Level/a/SortField/0/Default.aspx
