BS1 Tach application - replacing dual 4013 flip flop w/ single
I'm looking at using the Tachometer application in the "Basic Stamp 1 Application Notes", using a hall effect transistor and the 4013 flip flop.· This circuit uses 1/2 of the flip flop IC, since it is a dual.·
Is there a single flip flop IC that I can use in place of the "1/2 4013" solution presented in the manual? · I don't want the expansion capability and would rather use a single flip flop.
Donivan
Donivan
As far as I know, you're not going to a package with fewer pins.
