bs2 math
i am trying to compute vapor pressure with a bs2 and a sensiron shtx
the formula is·· e= 6.11*10.0**(7.5*t/(237.7+t))· where· e is vapor pressure and t is temperature in degrees celsius at a resolution of tenths of a degree.· Can this formulat be computed on the bs2?
However, this would be very easy to do with a PAK floating point coprocessor. The PAK12 uses ASCII RPN so it is dead simple to use. You can even define macros that would store you whole computation. See http://www.awce.com/pak12.htm.
The PAK-II (or the PAK-IX if you want A/D inputs also) will work. It uses a more efficient way of handling numbers, but that also makes it a little less inutitive to use. If you are worried about getting the most speed of a variety of computations, the PAK-II (or IX) is a good choice. However, the PAK-XII actually runs a bit faster, and if you use macros to cut down on the number of bytes sent between the Stamp and the PAK it can also achieve good speeds. See http://www.awce.com/pak1.htm for more on the PAK-II and IX (the PAK-I doesn't do everything you need, so it is out of consideration, but it shares a page with the PAK-II).
You can see examples of these at http://www.awce.com/doclib.htm
Al Williams
AWC
