Javelin vs. t630
Im currently using a Javelin Stamp on a demo board containing two rs232 connectors. one is connected to the computer's serial port com1, and the other is connected to the SonyEricsson t630.
I've tried connecting the second rs232 to the computers com2 in order to read the signals being issued by the Javelin Stamp in HyperTerminal and with Portmon. I discovered there is a difference between what HyperTerminal sends to the mobile, and what the Javelin chip does - both issuing the same AT-commands..
Appreciate any and all help
(sorry for cross posting!)
While trying to solve this problem I've been disconnecting and reconnecting the phone (SonyEricsson t630) without pulling the power plug on the stamp board. Twice while disconnecting the phone it started dialing, ie it started executing the AT-commands it was sent. This lead me to believe, that there is something wrong with the termination of the commands being sent from the board to the phone. I've tried a number of different combinations of \r and \n, but all yields nothing.
Please help if you have any clues. All help appreciated!
definition? It looks like it started dialing once you removed the handshake.
Also, have you tested your comport wiring with hyperterminal?
regards peter
I have tried the handshake both inverted and dontInverted with the same amount of success.
I have connected the board to com 2 to read its output in hyperterminal and advanced serial port monitor, and it seems to be alright. I'll post it here later.
The wiring on the board is according to Javelin Stamp User Manual 1.0 picture 4.8 b.
The code is as follows:
import stamp.core.*;
public class ModemTest
final static int SERIAL_TX_PIN = CPU.pin0;
final static int SERIAL_RTS_PIN = CPU.pin1;
final static int SERIAL_CTS_PIN = CPU.pin2;
final static int SERIAL_RX_PIN = CPU.pin3;
static Uart rxUart = new Uart(Uart.dirReceive, SERIAL_RX_PIN, Uart.dontInvert, SERIAL_CTS_PIN, Uart.speed9600, Uart.stop1);
static Uart txUart = new Uart(Uart.dirTransmit, SERIAL_TX_PIN, Uart.dontInvert, SERIAL_RTS_PIN, Uart.speed9600, Uart.stop1);
public static void main()
txUart.sendString("ATDT22563132\r");
txUart.sendString("\r");
while (true)
System.out.println((char)rxUart.receiveByte());
in your uart definition:
static Uart rxUart = new Uart(Uart.dirReceive, SERIAL_RX_PIN, Uart.dontInvert, SERIAL_CTS_PIN, Uart.invert, Uart.speed9600, Uart.stop1);
static Uart txUart = new Uart(Uart.dirTransmit, SERIAL_TX_PIN, Uart.dontInvert, SERIAL_RTS_PIN, Uart.invert, Uart.speed9600, Uart.stop1);
This allows you to try all four possible combinations.
data·········· handshake
dontInvert·· dontInvert
dontInvert········ invert
····· invert·· dontInvert
····· invert········ invert
One of them should be the right one.
regards peter
Thanks for all help!
I registered with Yahoo! to access the files at http://groups.yahoo.com/group/javelinstamp/ and - Lo and Behold! - I downloaded Andys HyperTermComNoFlow.java and it did the trick! Removing the flow control all together solved my problem, and I'm now happily throwing myself at the next problem!
Thanks again!
