Time card recorder
Hello all
I have a project I want to tell you about.
This is a description of what it needs to do:
A) Display time,HHMM, MMDDYYYY , on an LCD display
Be able to read a mag card swipe or Prox card
1) Compare Card ID with internal list of 100+ card ID's ( 32 bit ID)
2) If valid Card ID operate dry contact
3) Display " VALID" or " INVALID" on LCD
C) Record Time and Card ID into memory , at least 1000 entrys
D) Able to retrive Data by Modem, Unit to call a PC at a preselected time.
E) Battery backup to operate Clock display, card reader and relay 1/2 hr, Battery backup for Clock and Data for at least a week.
F) Overwrite previous data FIFO
G) Operate a second dry contact at preselected times at least 100 events
Items that are needed
Card reader
Memory for data,list, event time list and program
Backup battery
Modem
Clock
LCD Display
2 relays
Controller to run it all
Programming
Before I buy something I dont need or won't work and spend tons of time on this I thought I would ask all of you:
Does this sound like something the Parallax Stamp can do?
If it can, which version?
What accessories are available from Parallax?
How hard is it to integrate (other) hardware with the Parallax stamp?
Thanks for the forum
And thank you in advance for your replys
Rick
Card reader
Backup battery
Modem
Clock
LCD Display
2 relays
Programming
Rick
You could easily prototype your project with the BS2p24-40 demo board. It has an LCD connection, an AppMod connection, and plenty of breadboard space for other devices. That said, all of this is possible, but it's not something that you can expect to simply slap together and write a few lines of code.
Jon Williams
Dallas Office
That gives me a place to start. Although I have no experence with PBasic or Stamps, I don't think that each subsystem by it self will present to much of a problem. Working together as one system , well that's another story.
I think I'll break the project down into subsystems. Clock,Display, Store data, compare ID's to list, Event timer, Mag reader, transmit data. I think the tricky part will be comparing the card ID to a stored list of valid ID's.
Thanks for your reply
Rick
Jon Williams
Dallas Office
·· If you find a suitable Card Reader, or if you develop of good interface with an existing one and some code, I'm sure there are a bunch of people on here who would love to have you share those findings.· The RTC, LCD and datalogging stuff has been covered for a lot of applications, but card reading seems to be one of those user-dependant areas...Especially Prox cards...
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
Jon Williams
Dallas Office
My understanding is that the optical scan of a barcode produces a square wave that in turn needs to be decoded into a user readable format. What I do not understand is the relationship between time and bar width. One would think that swiping the card faster or slower would shoot the possibility of measuring via time. Exactly how is a barcode decoded as I have at least a couple of applications on the back burner waiting until I am a little smarter on the subject.
·· I was referring to Magnetic Strip and Prox readers...When it comes to reading Bar Codes, the hardware for them is fairly straigh-forward.· Being a hobbyist before anything else, I always take the "cheap" road.
·· Radio Shack used to give away free Cue-Cat Bar Code readers, which were capable of reading almost any UPC Bar Code, and even several other formats/variations.· When adjusted properly (Read: hacked), the Cue Cat outputs standard·data like a computer keyboard, sending the keyboard equivalents of the characters as if they were typed on a computer keyboard.· In fact many wedge between the keyboard and the computer's keyboard port.
·· There are many other wand and other Bar Code scanners that work this way, so if you could read a computer keyboard, you could read one of these Bar Code Scanners.· Parallax used to sell a device which might have helped with this...Keyverter.· I may have to try mine to see how effective it is in this manner.
Knight Designs
P.O. Box 97
(607) 535-6777
Try useing the relationship between white and black or on and off to·decode your barcode.· In other words compare how long it is on to how long it was off.
An alternative to a card swipe is the maxim iButton for ID. Here are a couple of sites with information and good source code.
http://pdfserv.maxim-ic.com/en/an/app204.pdf
http://www.maxim-ic.com/appnotes.cfm/appnote_number/1790
Jon Williams
Dallas Office
No biggie...I was just saying there are other routes to reading Bar Codes than the way the Mag/Prox readers are read, since on those I know many act like a keyboard wedge.
Knight Designs
P.O. Box 97
(607) 535-6777
