BS2E timing
Just finished two outdoor Christmas displays using identical components with no external capacitors that would affect timing. It is just a down right simple BS2E -·ULN2803 - solid state relay device.·If I plug them into the same extension cord and then to the wall, within a few minutes one display will be well ahead of the other in the program loop. Is this common? The reason for asking is for my next post RC Time...
All of this costs dollars and milli-amps, of course.
However, if you had another oscillator that *did* blink every 1 second, you would quickly be able to tell by comparing the two that they were not in syncronization. Part of the reason is of course that the difference increases every second.
I believe most people use a single Stamp at a time, and if they really want wall-clock time they use a cheap DS1302 RTS chip, so the discrepancy is not a problem for them.· Note that even a·32 KHz crystal controlled DS1302 will gain or lose a few seconds a day.
If the two units are within 10 feet of each other, I suppose you could use an IR-LED and an IR-Decoder to have one be the 'master' clocker and one the 'slave' clocker -- this would at least keep them synchronized with each other.
