coil connected to basic stamp: any danger?
Hi, I am a beginner and would like to do the following:
I want to connect a coil with a magnet inside to my basic stamp. I want to control the magnet, that can move forth and back, when voltage is applied.
Now I am wondering: How do I connect the coil to my basicstamp? Is there any danger for my bs2, as coils are trying to keep the current flowing when the voltage is unapplied?
Can I simply use pulsout to apply a certain voltage to a certain pin?
thanks a lot
debianizer
thanks a lot
debianizer
Sid Weaver
New Combo LCD Backpack
But how do I connect to the basic stamp? is there a link with some circuit similiar to mine somewhere?
simply p0 and vdd or how?
thanks
Jon Williams
Dallas Office
Sid Weaver
Could we get a little clarification from the poster?· Does the magnet need to move both ways, or can it be returned via a spring?
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
Post Edited (Chris Savage) : 10/31/2004 4:22:07 PM GMT
so the described circuit should work for me?
thanks
debianize
Knight Designs
P.O. Box 97
(607) 535-6777
Post Edited (Chris Savage) : 10/31/2004 9:56:20 PM GMT
so thanks alot, I will try to build what you guys advised me.
The 'strange' behavior of your magnet may be not so strange at all.
The piston that goes into your coil is probably not a magnet. It is iron and it gets magnetized by the coil and then jumps into the coil when it is activated. As it does not have a magnetic North and South by itself it just jumps in, no matter which direction the current in the coil flows and how you put in the piston.
That is the miracel
Klaus
thanks
debianize
Yes, you do have to have current in the coil.· That current creates magnetic flux around the coil.· When an iron core comes near it is magnetized by the flux and attracted to the coil.· The center of the coil has the highest density of flux so the attraction there is the strongest.· There should be no current to speak of in the piston just the coil.·
This is just a basic explanation.
