Please Help with the Motor Mind C
I bought the motor mind C and the carrier board and was just wondering if someone can help me with a program to start·the motor with·a pushbutton and have it run for a set period of time.
Kidd
Kidd
Have a look at the manufacturers web site, there are a couple of example apps and explainations reguarding usage of MMC. The link is:
http://www.solutions-cubed.com/solutions cubed/MMC2003.htm
Reguarding the push button, I assume your using a BS2, check the StampWorks manual from www.parallax.com (on the downloads menu) - they have examples of using a BS2 IO pin to detect a push button. You can then use some code to wait for a duration or until an event occurs, i.e. perhaps a distance sensor detects a wall.
http://www.parallax.com/html_pages/downloads/sw/sw.asp
Hope this helps.
