NEED TO GRADUATE - SENIOR PROJECT with BASIC Stamp — Parallax Forums
cocococo Posts: 4
edited 2004-11-01 20:25 in BASIC Stamp
Hello !
I have never used PBasic language but for my senior project, I'm trying to slimulate a RADAR device.
I have·:
the·Basic Stamp 2 Module
the EmbeddedBlue Transceiver AppMod
the Board of education
the SRF08 Ultrasonic Range Finder
My intent is to·detect and locate a moving object.
    edited 2004-10-29 20:10
    If forum members help you with YOUR work, are you going to report this to your instructor?·
    Be sure to download and read the following text books -- they will help:
    * What's A Microcontroller?
    * Basic Analog and Digital
    * Applied Sensors
    * Industrial Control
    All are free (as PDFs) and can be found on our web site.
    Jon Williams
    Dallas Office
    Post Edited (Jon Williams) : 10/29/2004 8:44:10 PM GMT
  • K de JongK de Jong Posts: 154
    edited 2004-10-29 20:20
    Well Jon,
    Just bring in some very clever code, HE will have to explain this code to his instructor smile.gif)))))))))))
    edited 2004-10-29 20:21
    That's MY particular "problem" -- I always write code that a ding-dong like me can understand!
    Jon Williams
    Dallas Office
    edited 2004-10-29 20:41
    Let's wait and see.......,
    Klaus
  • cocococo Posts: 4
    edited 2004-10-29 20:55
    I just need an idea on how to approach this project. I have some basic background on C++.
    But once again, the project has to be done in PBasic.
    edited 2004-10-29 23:04
    If you're a C++ programmer then PBASIC will be no challenge -- other than managing resources since their very small on an embedded micro. The books I referenced will get you going.
    Jon Williams
    Dallas Office
  • Ken GraceyKen Gracey Posts: 7,407
    edited 2004-10-31 00:49
    Coco,
    Seems like you will also need a servo on which to mount your SRF04 so you can make a sweep.
    This should be an easy project.
    Something like this:
    DO:
    Rotate servo a few degrees
    Ping ultrasonic sensor
    Get results
    Send them via RF to PC (servo angle and distance to object)
    Increment Servo position
    LOOP
    For the PC-side display, you might want to look at StampPlot Pro (free educational download) or simply use the DEBUG terminal with asterisks to show distances to objects. There's also a cool data logging program StampDAQ that imports data into Excel real-time (well, as real as serial gets). You could then create a scatter diagram in Excel to show the data.
    And you made another post about USB. You could send the data into the PC via USB if you desire.
    This is a nice project, feasible and interesting. You should have no trouble getting it put together. Build it one step at a time and ask us specific questions along the way.
  • cocococo Posts: 4
    edited 2004-10-31 22:05
    How can I connect the SRF08 to the board of education? I never use it before and I don't want to blew my equipments.
    The manual tells me to connect the SCL and SDA lines to pull-up resistors connected to +5v.
    Do I use jumper wires.
    Im using a basicStamp2 module.
    Thanks for your feedback
    edited 2004-11-01 02:13
    Coco,
    Have you seen this:
    http://www.robot-electronics.co.uk/htm/srf08stamp.shtml
    edited 2004-11-01 15:15
    Yes, you need two 47 KOhm pull-up resistors (wired between +5 and the data line).
    If the schematic on the above link doesn't come up at first, hit 'refresh' on
    your browser.
  • steve_bsteve_b Posts: 1,563
    Something else to think about....are you planning on having continuous 360deg rotation?
    If so, then a standard servo will be just fine (come in 90deg and 180deg rigs).· If you want continous....then you'll have to buy a modified servo (or buy a premod'd one) that will do continuous 360 rotations.
    Of course, this brings another problem.· you need to run at least 3 wires to the SRF sitting on top of this servo.· So....unless you are only going to do a couple rotations one way...then reverse directions to allow the wires to un-wind....then you'll want to look at getting some sort of slipring apparatus (or make your own).· The sliprings are just little metallic wires sitting in metal grooves that are attached to the shaft and rotate.· The signal goes through these grooves to the wire spring-like thing and down the normal paths from there on.· There are different ways of achieving the same thing (some use little ballbearings in a cup that rolls along a metal path to do the same thing....).
    As far detecting moving objects....well....you'll need to keep track of your steps inorder to ascertain the direction you are ranging.· As the servo will advance 2.5deg (depending on your servo) with each pulse from the stamp...you'll have to know where the SRF is pointing in the first place to know your starting point....then for each pulse you add 2.5 to your previous direction value.
    Tracking an object that isn't necessarily the closest thing to you might be tricky.
    I'd say, use one of those CMUcams and the radar.·· Use the radar to plot a template of the area...any 'new' echo's would be a case to have the CMUcam turn towards it and use the pixel tracking in it to track your object that way!
    Steve
    http://members.rogers.com/steve.brady
    http://www.geocities.com/paulsopenstage
