vertical ballbearing rail
Hello again [noparse]:)[/noparse]
Got a fabrication question·for you'll this time...
I have been using a rail (like out of a server case) for attaching an object
that needs to go up and down ~40 inches (I had to weld 2 of the rails
together and do some magic..) the object attaches to a chain and then a
sprocket at each end then a motor at the top.······ I used the rail out of a
server because I need a very low profile rail
Basically, I think this is a crappy execution of what I had in
mind(basically because of the weld.. and the object on the rail will snag
sometimes)...
So I am trying to find a very low profile rail that is ~35-40 inches long.
I found some on mcmaster carr, but they are pretty expensive..
Do you'll have any other suggestions on places that I could purchase this
from? (granted I might need to keep ordering more and more.. so it cannot be
a single auction on ebay[noparse]:)[/noparse]..
what I found on mcmaster carr was:
http://www.mcmaster.com/
look up item
6004K11
bottom 2 sections
any help would be great, because I honestly feel that these prices are very
inflatted.
thanks!
Lee
sometimes)...
look up item
6004K11
bottom 2 sections
inflatted.
thanks!
Lee
may be okay for a lightly loaded system.
BTW, you will be hard pressed to find an easier or quicker source than McMaster-Carr. They are a fine supplier.
Dave G
The thing is, these products from mcmaster are very high quality and have a high load capacity.. I don't really need a high capacity at all.. So I was hoping there was other solutions out there.
I had just hoped someone had experience with finding cheaper rails.
thanks for you'lls input!
Lee
-dave
This is not a sig. This is a duck. Quack.
thanks! Lee
Look at the pictures on this site :
www.crankorgan.com/
Larry
-dave
