Midi in -- relay, solenoid out?
Does someone know of a source of Basic Stamp code that is designed to listen to an input stream of Midi commands and then control up to 24 relays, solenoids or other devices?
Many thanks in advance.
Bill
On a bayou in Mississippi
Bill
Jon
On the plains of North Texas
Jon Williams
Dallas Office
I might be able to write something myself but I sure would like to find someone who "had shot this bear" before! ;-)· The baud rate is 30k+ (a little; 31.2K?) so should be within the range of a Stamp module.
Writing the code to decode the midi string (See: http://improv.sapp.org/doc/misc/MidiFileFormat.html) will be the hardest part and I was hoping to tie into someone that might have already done this.
Hear is hoping!
Take care
Bill (on a bayou in Mississippi)
http://www.parallax.com/dl/docs/cols/nv/vol4/col/nv94.pdf
http://www.parallax.com/dl/docs/cols/nv/vol4/col/nv95.pdf
Jon Williams
Dallas Office
Here is the reason that I see this as an interesting project.· If you can accept a Midi stream and convert that to relay or solenoid activation then you can control chimes (my application), gongs or pluck strings.· All in sync with another sound maker or instrument.· The possibilities are quite far reaching.·
Take care
Bill
On a Bayou in Mississippi
Jon, although I've seen this discussed in various threads before, I still don't have a good feel for the max. baud rate a BS2 can work at. In my case I am interested in the max baud rate from BS2 to BS2, using the flow control pins? I haven't pushed the envelope myself, only trying up to 9600. Can I expect 19.2K or 38.4K to work reliably (over short distances, e.g. 1 foot or less)?
bayoubill's project is like an updated version of an early 20th century music machine (Mills Violano for example).
Thanks.
Harry
Without flow control or formatters, the BS2 can handle nearly 50 kBaud, and dealing with 31.25 kBaud MIDI is no trouble (transmitting that is, decoding MIDI on the fly is really difficult).
Jon Williams
Dallas Office
Harry
