datalogger using a stamp
I'd like to build a single-channel data logger using a basic stamp. I assume that the BS2pe is the best model for doing that. Do I need additional chips like clock chips or external memory chips or anything? Does the stamp keep the time by itself? If the stamp is reading the value from a 12-bit A/D converter, how many readings will it hold before the memory fills up?
Thanks.
Thanks.
Jon Williams
Dallas Office
