Static Protection
I'm using a stamp inside the "hull" of a plastic vehicle. I noticed that the hull was a very good static collector- like when Dremeling away at unwanted plastic, the chips all clung to the hull.
I later installed some electronics, including a BS2. Worked fine one day, but one PIC and the Stamp were DOA the next day.
Dang, must have been the static I figgered, so I ran a ground wire from the electronics to the plastic hull. No problems since.
Does this make sense, and is there anything better to do to protect against the effects of static?
Pat M
