Editor complaining about CD Drive
The latest Editor (2.1 - R2) complains when it starts up about not having a disk in the CD/DVD drive. After clicking Continue a couple of times it ultimately loads.
Is there something I can change to make it not ask that a disk be put into the drive? I've uninstalled and reinstalled to no avail.
Kenny
Kenny Gardner
GAP Development Company
http://www.gapdev.com/
Kenny
Kenny Gardner
Igal
I'm alerting Jeff Martin right away (our BASIC Stamp Windows Editor Engineer and CD creator).
I'll ask him to reply to the forum.
I think the problem may be related to an issue with the editor's integrated explorer.· Is the CD ROM drive an external USB device?· Or do you have a Media reader (for SmartMedia, Flash Memory, etc)?
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
My CD/DVD drive is internal.
The next day, after a reboot, the Editor quit complaining about there being no disk in the drive.
Here's what I've discovered:
Put a CD in the Drive. Load the Editor. Exit the Editor and then remove the CD. Load the Editor again and it will complain about there not being a CD in the drive.
Rebooting apparently clears some setting.
HTH,
Kenny
Kenny Gardner
Jeff, I do have a flash card reader in my HP printer. Could that be causing the problem?
Muggs
Yep. I just plugged in my Flash Reader and loaded up the Editor and sure enough, it told me to insert a disk into the reader.
Kenny
Kenny Gardner
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
I'm new to this fourms but I've had a BOE bot for a few years. I believe Jeff Martin is correct. When the editor boots, I think it's looking in external drives, not internal ones. I kept having the problem and I tried multiple uninstallations and reinstallations with no success. However, I noticed that I had a flash memory card reader hooked up to a USB port, which was causing the problem. The editor now works perfect for me, no error, when I have the card reader unplugged. Hope this helps.
-D.X.
Unreal tournament 2004 rox
