SX Current Consumption — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2004-10-23 01:10 in General Discussion
Hi to all geniuses,
Anybody knows what is the SX28AC current consumption like if the reset (MCLR) is pulled low?
Is it the same as in sleep mode?
Another question,
Is the SX current consumption lower when running with Internal oscillator or when running with external crystal at the same frequency and voltage?
Thanks.
  • James NewtonJames Newton Posts: 329
    edited 2004-10-22 17:20
    Is this not in the Datasheet?
    James Newton, Host of SXList.com
    james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
    SX FAQ / Code / Tutorials / Documentation:
    http://www.sxlist.com Pick faster!
  • william chanwilliam chan Posts: 1,326
    edited 2004-10-23 00:36
    I can't find this info in the Datasheet. !
    Reset (MCLR low) is not a low power state. The current is practically the the same as the operating current.
    I couldn't find it in the data sheet either. So I investigated it myself. I was primarily interested in the behavior of the BASIC Stamp as it goes into brownout, and found glitches anyone who has to deal with system reliability should be aware of. Strange things happen if the SX is in SLEEP when the brownout occurs.
    www.emesystems.com/BS2power.htm#Brownout
    There is also discussion of tests on a raw SX chip, where the watchdog could be disabled.
    Tracy Allen
    www.emesystems.com
