RS232 Circuit
I had a BS2 interfaced to a digital scale (Pelouze 4040) through RS232 and it worked flawlessly for the past 2 years.· But it stoped all of a sudden.· The pin on the BS2 is fine - I tested it with another RS232 device.· When I hooked the scale to a brand new BS2 al I got was meaningless data.· I have the RX line (I don't actually use the TX line) from the scale goes directly to the pin and of course a common ground between the scale and the BS2.· Should I have some resistor there to protect the pin or the scale itself?· I bought a new scale and want to make sure I have a safe connection.
Many thanks,
Al Najjar
Many thanks,
Al Najjar
It is possible the scale RS-232 communication just broke -- or perhaps the baud rate has changed? That could give the results you call out.
