max7219 assist
hail,
this is bugging me to the max!
i have devised a crude prototype with a max7219 connected to a 8X8 led array. the module is controlled by a bs2p on a nx1000
when ever i try to light up·row 1 or 2 on the matrix (the equivalent to displaying a 8 +dp on a 7-seg) the module· goes dark and stops working for any future commands. the stamp continues to shift data.
any help would be well received
rox on
nick bernard
rox on
nick bernard
Jon Williams
Dallas Office
my code works fine so does KenMs
i think that there is a problem with my circuit that is causing the fault i just dont understand why the 7219 stops accepting commands after the fault, which occurs when i write a 255 to the·1st·or·2nd·digit.
if there was a problem with the led matrix then why would it work fine counting up to 254 on every digit but fail at 255 on the first and second digit,
is there an exception in the max7219 that shuts the chip down in over current situations or something?
DO
FOR digit = 1 TO 8
FOR value = 0 TO 250
PAUSE 5
GOSUB row
NEXT
NEXT
LOOP
Row:
SHIFTOUT DAT,CLK,MSBFIRST,[noparse][[/noparse]digit,value]
PULSOUT LOAD,1
RETURN
if the current draw was to much for the nx-1000's 5v reg could that lock the system
rox on
nick bernard
·· Is the NX's regulator getting excessively hot?· Can you touch it?· If so it shouldn't be overheating...Besides, there really isn't that much of a difference in the current draw from 254 to 255...I mean close to the same number of LEDs should be lit.· It's not like an 8, where the most are lit...I would think all 8's across the board would be more likely to do something like that.
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
i can now count all registers up to 255; nothing has changed, honestly. However the 8X8 matrix will go dark if i up the intensity past 2. also there is a definate relation between the intensity and the number of led's lit at the time of the fault. (higher intensity : fewer digits)
i can also count all registers up to 254 with higher intensity, it does freeze at max (15) though
the more i think about it the more it seems like a current problem that will drop the supply voltage enough to interrupt the data flow but not to reset the stamp (i set up a debug to test that case).
rox on
nick bernard
Knight Designs
P.O. Box 97
(607) 535-6777
if i set the intensity to 15 then the following
FOR digit = 8 TO 1
FOR value = 0 TO 255 ' the ic locks up after digit = 1 value = 255
PAUSE 5
GOSUB row
NEXT
NEXT
FOR digit = 1 TO 8
PAUSE 5
GOSUB row
NEXT
NEXT
the current resistor is 10k on the max7219 btw
rox on
nick bernard
·· I'm glad you got it figured out based on input back to you...·
Knight Designs
P.O. Box 97
(607) 535-6777
On my set up I used a 47k ohms for the current resistor of the 7219.
With that resistor, I had no problem with intensity settings up to $A (did not go past $A)
fyi
i switched to a 47k current resistor and now the beast works fine fine like muscadine wine.
thx to all for the assist
rox on
nick bernard
