Circuits Question
http://www.velleman.be/Downloads/0/Manual_MK104.pdf
I am an ME with a simple EE question.·In the attached schematic, what is the purpose of the resistor in parallel with the buzzer in the upper right corner?· If I wanted an LED to come on when the buzzer was on, I would do the circuit analysis such as (Vsource - Vled) / (rated LED current)· to come up with the correct series resistor right?· With an LED, would I still put that resistor in·parallel with the buzzer?
Pat
Pat
Thus the resistor in parallel with the piezo accomplishes this. It might help to think of a piezo as a capacitor, they both have similar characteristics.
As for the led, the formula you have is·correct, but if you still want to use the buzzer, I would leave the resistor in parallel.
- Beau Schwabe
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
Post Edited (Beau Schwabe) : 10/19/2004 3:00:25 PM GMT
you removed the resistor you would hear an initial "click", and then perhaps a very weak "buzz" (due to internal resistive leakage)... by applying a resistor, the piezo discharges much
faster relaxing the shape of the crystal so that the next pulse causes it to deflect again. More deflection = more pressure or volume
See...
Parallax Forums > Public Forums > Stamps In Class > Amplifying piezo speaker
...for some other details.
Mail Stop GA1
Norcross,GA 30071
one terminal of a series resistor (Resistor Value determined below) and connect the other resistor termianl to D1's cathode.
A K
The resistor value should be....
Rled = ( Vsource - Vled ) / Iled
Where:
Vsource =7.8V (remember you have three diode drops; one across T1 another across D1, and a third across your LED)
A typical transistor diode drop is about .6 Volts, so 9V - 1.2V = 7.8V
Vled =1.7V (typical - you can measure this with a digital volt meter on the diode setting)
Iled =10mA (typical)
Rled = ( 7.8V - 1.7V ) / .010A = 610 Ohms or closest standard value
Mail Stop GA1
Norcross,GA 30071
