controlling a 10 pin, 4 bit LCD module
I have a 10 pin, 4 but LCD module I got from BG Micro a while back, and the data sheet is just awful, and I'd like to white a prog to control this thing. The data sheed can be found here: bgmicro.com/pdf/2x16el.pdf. I would like to use pins 0-6 to control the R/S, R/W, CE, DB-4, DB-5, DB-6, and DB-7 pins on the LCD module. If there is already some sample code for controlling a 4 bit lcd, I would love to see it. BTW for those of you looking at the data sheet, mine is the 2x20 display.
Thanks for looking,
Justin
Thanks for looking,
Justin
Jon Williams
Dallas Office
