Interfacing the BS2 to computer (cap question)
Hello, I am looking to program my bs2 via mycomputer... I don't have enough time to buy a carrier board, so I was going to make· one myself and buy the board later..
Anyways, I was looking at this schematic:
http://www.parallax.com/dl/docs/prod/boards/BOERevC.pdf
And wondered, if I could use these caps:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=121928
becuase I already have them... I was just confused about this info on the page:
Ceramic Disc Capacitors (+/-20%)
25 Volt, 50 Volt, and 1000 Volt, Z5U Temperature Coefficient
thanks! Lee
thanks! Lee
http://www.parallax.com/dl/docs/prod/boards/stamp2carrier.pdf
? or is there a better way to do it?
thanks! Lee
My only last question is, it says that bs2 stamp pin4 goes to ground, pin3 (after going throught a cap) goes to ground and pin5 of the serial cable goes to ground... can that ground be the ground from the 9v battery?
thanks
Lee
